[GRASS-user] m.viz.image Command Line
Martin Landa landa.martin at gmail.com
Tue Jan 17 10:30:53 EST 2012
2012/1/17 Martin Landa <landa.martin at gmail.com>:
> This behaviour should be changed. If you do not define multiple values
> for given parameters (like `wire_color`) then the module should use
> default (single) value for all loaded surfaces.
ops, I overlooked (`-a` flag) see Anna's answer.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
