[GRASS-user] m.viz.image Command Line
Anna Kratochvílová kratochanna at gmail.com
Tue Jan 17 14:15:12 EST 2012
On Tue, Jan 17, 2012 at 7:04 PM, Rich Shepard <rshepard at appl-ecosys.com> wrote:
> On Tue, 17 Jan 2012, Anna Kratochvílová wrote:
>> Maybe you could show the whole command and error, I'm a little lost what's
>> the problem now.
> Anna,
>  Yes, it's easy to become confused. Here's what I wrote in reponse to
> Martin's message with sample command:
> Martin,
>   It's a good idea to get this working one part at a time. So I copied the
> above into a shell script and changed the elevation_map names to the
> specific ones I need to use. I'm still getting the same error:
>   Script:
> m.nviz.image elevation_map=aber5m,mompano_rast out=elev mode=fine,fine
> resolution_fine=6,6 resolution_coarse=9,9 style=surface,surface
> shading=gouraud,gouraud wire_color=136:136:136,136:136:136
> produces,
> GRASS 6.5.svn (Oregon):~/grassdata/Oregon/beaver_lake > ./trial.sh ERROR:
> Inconsistent number of attributes (<elevation_map/elevation_value>
>        2: <mode> 1)
>  I keep getting the same error no matter the command entered. It should be
> easier to debug with only the two raster maps. Once it's working with those
> I can add the vectors/points.
The script above works for me (for my rasters), are you sure you use the same?
Anna
> Thanks,
> Rich
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
