[GRASS-user] Re: GRASS EXAMPLE
Sören Gebbert soerengebbert at googlemail.com
Sat Jan 21 15:57:54 EST 2012
Hi Hrachya,
make sure you started a valid grass session before you execute any
grass command.
Does only r.example segfault or any other command too?
Best
Soeren
Hint:
I would avoid to use the root account when working with grass ....
2012/1/21 Hrachya Astsatryan <hrach at sci.am>:
> After the compilation, r.example gives "Segmentation fault"
> [root at wn1 r.example]# /usr/local/grass-6.4.2svn/bin/r.example
> Segmentation fault
> On 1/21/12 11:03 PM, Martin Landa wrote:
> Hi,
> I have installed successfully the Grass via elgis.repo (see below)
> [root at wn1 grass-6.4.1]# yum list|grep grass|more
> grass.x86_64                             6.4.1-2.el5.elgis
> installed
> grass-devel.x86_64                       6.4.1-2.el5.elgis
> installed
> grass-libs.x86_64                        6.4.1-2.el5.elgis
> installed
> So What should I do else?
> well, GRASS 6.4.2 has been released yet, you could try to compile
> GRASS [1] on your own or to wait for 6.4.2 release. Quick solution
> could be to copy `Make` directory from SVN [2] to your `include`
> directory. Anyway `grass-devel` seems to be incomplete in this repo.
> Martin
> [1] http://trac.osgeo.org/grass/wiki/BuildingOnUnix
> [2]
> http://svn.osgeo.org/grass/grass/tags/release_20110412_grass_6_4_1/include/Make/
> Hrachya Astsatryan
> Head of HPC Laboratory,
> Institute for Informatics and Automation Problems,
> National Academy of Sciences of the Republic of Armenia
> 1, P. Sevak str., Yerevan 0014, Armenia
> t: 374 10 284780
> f: 374 10 285812
> e: hrach at sci.am
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
