[GRASS-user] Why r.watershed Yields Narrow Basins
Rich Shepard rshepard at appl-ecosys.com
Fri Jun 8 14:54:04 PDT 2012
On Fri, 8 Jun 2012, Rich Shepard wrote:
>  Sample maps can be provide if desired.
   Attached is such a map. The base DEM has a 10mx10m resolution (source:
National Elevation Dataset). The black lines are the HUC-12 sub-watershed
boundaries from the National Hydrographic Dataset. The red lines are the
vectorized bounds from r.watershed with a threshold of 125,000.
   I'd like to understand why some of the r.watershed basins look like
squashed worms.
Rich
Type: application/pdf
Desc:
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20120608/5b573736/attachment-0001.pdf>
