[GRASS-user] VOXEL will not display (3D geological volume modeling)
davidalvarez76 davidalvarezgisfl at gmail.com
Tue Jun 12 05:32:52 PDT 2012
Hi
My DSM goes upto 2300 ft and my lowest geology goes to 530 ft. So I set up
my upper limit as 2300 and my lower limit as 500.
g.region  t=2300  b=500 res3=1 tbres=5
Thank you,
David
On Tue, Jun 12, 2012 at 4:16 AM, gene [via OSGeo.org] <
ml-node+s1560n4980669h77 at n6.nabble.com> wrote:
> Hello
> In my experience, the problem lies in defining the upper and lower limits
> of the 3D region (see 3D geological volume modeling (raster 3D): is it
> really possible ?<http://osgeo-org.1560.n6.nabble.com/3D-geological-volume-modeling-raster-3D-is-it-really-possible-td4980148.html>)
> with bad lower limit:
> with appropriate lower limit
> No problem with Paraview, but I am still unable to view it in nviz. I do
> not understand the use of isosurfaces in this case.
>  If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.n6.nabble.com/VOXEL-will-not-display-3D-geological-volume-modeling-tp4980404p4980669.html
>  To unsubscribe from VOXEL will not display (3D geological volume
> modeling), click here<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4980404&code=ZGF2aWRhbHZhcmV6Z2lzZmxAZ21haWwuY29tfDQ5ODA0MDR8MzE1ODQ2OTI5>
> NAML<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.n6.nabble.com/VOXEL-will-not-display-3D-geological-volume-modeling-tp4980404p4980776.html
Sent from the Grass - Users mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20120612/09b4957d/attachment.html>
