[GRASS-user] NVIZ can't allocate enough memory
Markus Metz markus.metz.giswork at googlemail.com
Tue Jun 12 06:13:30 PDT 2012
On Tue, Jun 12, 2012 at 5:23 AM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Daniel Lee wrote:
>> ERROR: G_malloc: unable to allocate 18446744071974792324 bytes at gsds.c:575
> 18446744071974792324 = 0xffffffff9899ac84
>> Does anybody know what could be the problem? If I'm interpreting the bytes
>> correctly, that'd be about 10^10 gigabytes, which several orders of
>> magnitude larger than the rasters involved. Thanks!
> A calculation has overflowed the range of a signed 32-bit integer
> resulting in a negative value. This value has then been converted to a
> signed 64-bit integer, and then to an unsigned 64-bit integer.
>> Here's the output of g.region:
>> rows:       32001
>> cols:       20001
>> cells:      640052001
> At 4 bytes per cell, 640052001 cells = 2560208004 bytes.
> 2560208004 = 0x9899ac84
> The maximum value representable by a 32-bit integer is 0x7fffffff =
> 2147483647.
> Using an unsigned integer would eliminate the problem in this
> particular case, but the region wouldn't need to be much larger in
> order for that to be insufficient (specifically, 32001 x 33553 would
> overflow).
> The correct solution is to use "size_t" rather than "int". E.g. for
> this specific case:
> --- gsds.c      (revision 52015)
> +++ gsds.c      (working copy)
> @@ -481,7 +481,8 @@
>  int gsds_alloc_typbuff(int id, int *dims, int ndims, int type)
>     dataset *ds;
> -    int i, siz = 1;
> +    int i;
> +    size_t siz = 1;
>     if ((ds = get_dataset(id))) {
> More generally, it's important that the conversion comes before the
> mulitply; e.g.:
>        size_t cells = (size_t) rows * cols;
> will work but:
>        size_t cells = rows * cols;
> won't; the calculation will be perfomed using "int", overflow, then
> the overflowed result will be promoted.
> However: the number of instances of this particular issue in the GRASS
> source code is probably somewhere between "dozens" and "hundreds", and
> there's no systematic way to identify them. Running test cases with a
> region of >= 2^32 cells (or even >= 2^29 cells, i.e. >= 2^31 bytes at
> 4 bytes per cell) would find a lot of them, but it requires a 64-bit
> system with plenty of RAM, and it's going to be slow.
I have started modifying some libs, but still need to fix (checks for)
return values.
Markus M
> Glynn Clements <glynn at gclements.plus.com>
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
