[GRASS-user] Accuracy assessment
Stefan Sylla stefansylla at gmx.de
Fri Jun 15 09:54:12 PDT 2012
Hi Danut,
You can import the shapefile to grass with v.in.ogr. Then u should convert the vector to a raster with v.to.rast, using the same categories as for ur image. Then you should be able to perform r.kappa.
Stefan
Gesendet mit BlackBerry® Webmail von Telekom Deutschland
-----Original Message-----
From: "Danut Mihon [via OSGeo.org]" <ml-node+s1560n4981775h73 at n6.nabble.com>
Date: Fri, 15 Jun 2012 09:49:20
To: Stefan Sylla<stefansylla at gmx.de>
Subject: Accuracy assessment
I want to apply the r.kappa operator in order to perform the Accuracy assessment. The problem is that I have one GeoTIFF input as the thematic map, and the referenced input is in a .shp file. Converting the .shp file to a GeoTIFF seams to be problematic. Is there any way to use the r.kappa operator with the .shp file as second input? Or maybe you have other ideas how to overcome this situation.
Thanks in advanced,
Danut
grass-user mailing list
grass-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-user
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.n6.nabble.com/Accuracy-assessment-tp4981775.html
To start a new topic under Grass - Users, email ml-node+s1560n3884509h27 at n6.nabble.com
To unsubscribe from Grass - Users, visit http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=3884509&code=c3RlZmFuc3lsbGFAZ214LmRlfDM4ODQ1MDl8LTExNTE4ODczMTc=
View this message in context: http://osgeo-org.1560.n6.nabble.com/Accuracy-assessment-tp4981775p4981776.html
Sent from the Grass - Users mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20120615/6af5001a/attachment.html>
