[GRASS-user] Projection Confusion
Rich Shepard rshepard at appl-ecosys.com
Fri Jun 15 13:54:46 PDT 2012
   It took a while today for me to figure out where I went off the rails
importing a text file in Lat/Lon coordinates to Nevada East State Plane
Coordinate System, NAD 83, US Survey Feet (epsg:3421) using cs2cs. Still,
I've become confused because of the apparent switch in projection coordinate
sequence. Let me explain.
   The script file begins like this:
cs2cs -r +proj=latlong +datum=NAD83 +to +init=epsg:3421 <<EOF
+41.42188333    -115.99418333
with the latitude first and the longitude second. What continues to throw me
is that the output apparently has the longitude (easting) first and the
latitude (northing) second:
543495.65	28676372.70
   I confirmed this by using a Web page that does the conversions:
Latitude	41.42188333
Longitude	115.99418333
Calculated Values - based on Degrees Lat Long to seven decimal places.
Position Type	Lat Lon
Degrees Lat Long 	41.4218833°, -115.9941833°
Degrees Minutes	41°25.31300', -115°59.65100'
Degrees Minutes Seconds 	41°25'18.7800", -115°59'39.0600"
State Plane X Y (Meters)	2701 165657.806mE 8740575.881mN
X Y (US Survey Feet)		2701 543495.651ftUSE 28676372.703ftUSN
X Y (International Feet)	2701 543496.738ftE 28676430.056ftN
   Why this change in coordinate order?
Rich
