[GRASS-user] Feet-to-Meter Conversion
Markus Metz markus.metz.giswork at googlemail.com
Mon Jun 18 08:56:55 PDT 2012
On Mon, Jun 18, 2012 at 5:46 PM, Rich Shepard <rshepard at appl-ecosys.com> wrote:
>  The standard conversion factor from feet to meters is 1 ft = 0.3048 m.
> However, the conversion factor for US Survey Feet (frequently the distance
> unit in the US State Plane Coordinate System) is 1 US ft = 0.3600 m.
Are you sure? I thought 1 US survey foot is exactly 1200/3937 m, appr.
0.3048006 m, or the other way around 1 meter = 3.280833333 U.S. Survey
Feet [0].
Markus M
[0] http://www.ngs.noaa.gov/faq.shtml#Feet
>  I don't know the magnitude of the error when GRASS assumes international
> feet (0.3408) as the conversion factor. When I have a project location in
> SPCS is there any harm in manually changing the PROJ_UNITS from 0.3048 to
> 0.3600?
> Rich
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
