[GRASS-user] calculate mode value on moving window (with mapalgebra) with null value cells
Markus Metz markus.metz.giswork at googlemail.com
Tue Jun 19 06:15:29 PDT 2012
On Tue, Jun 19, 2012 at 12:39 PM, G. Allegri <giohappy at gmail.com> wrote:
> Hi Marcello,
> thanks, but my problem is not finding the border. I already have it (with
> its own category) but assigning it the value from the surrounding (not null)
> value, e.g. max/min/etc.
> The problem with kernel filters/moving windows is that they do not filter
> out null values...
AFAICT, r.neighbors ignores NULL values and assigns the new value from
the surrounding non-NULL values. You could then patch your original
map with the output of r.neighbors.
HTH,
Markus M
> giovanni
> 2012/6/19 Marcello Gorini <gorini at gmail.com>
>> G. Allegri wrote:
>>> I need to assign values to a the cells on the "border" of a raster. The
>>> inside and the outside are distinguished by having or not having null values
>>> assigned.
>>> I also need to keep the other cell values (internals) untouched.
>>  Hey,
>> Check out r.grow. I am pretty sure you can modify the example given in the
>> manual to find the borders of your raster. Something like:
>> # creates an inverted raster from your raster
>> > r.mapcalc "raster_inverted=if(isnull(raster,1,null())"
>> # grow this inverted raster by one cell
>> > r.grow in=raster_inverted out=raster_inverted_grown
>> # now both rasters overlap at the border, so you can do whatever you want
>> with it, for instance, extract it
>> > r.mapcalc "border=if(raster_inverted_grown==1 &&
>> > isnull(raster)==0,raster,null())"
>> Hope it helps.
>> Cheers,
>> Marcello.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
