[GRASS-user] landsat import with python-script
Stefan Sylla stefansylla at gmx.de
Fri Jun 22 06:19:49 PDT 2012
Hi Rasmus,
right, the "grass shell" is the command line window. 'Shell' because it's
the linux shell console (but grass command line also works on other
terminals).
I guess the syntax for starting a python-script in windows will be slightly
different.
Yes, the script should be in the working folder if you do not specify the
location further.
Stefan
View this message in context: http://osgeo-org.1560.n6.nabble.com/landsat-import-with-python-script-tp4366043p4983229.html
Sent from the Grass - Users mailing list archive at Nabble.com.
