[GRASS-user] error in r.sun with latin and longin maps
tigrida adriana.mata at ipicyt.edu.mx
Wed Jun 27 12:36:32 PDT 2012
Hi all
I want to create a map  with r.sun  but I get the following error:
Mode 1: instantaneous solar incidence angle & irradiance using a set local
time
pj_transform() failed: latitude or longitude exceeded limits
my  instruction is:
r.sun -s elevin=dem aspin=aspecto.allen slopein=pendiente lin=3.0
albedo=albedo_178  latin=latitud longin=longitud
beam_rad=beam_inst_pixel_178 diff_rad=diffuse_inst_pixel_178
refl_rad=reflected_inst_pixel_178 day=178 step=0.5 declin=0.406818033
time=11.11667 dist=1.0 numpartitions=1
r.info latitud:
  Type of Map:  raster               Number of Categories: 255             |
 |   Data Type:    FCELL
 |   Rows:         7231
 |   Columns:      8051
 |   Total Cells:  58216781
 |        Projection: UTM (zone 14)
 |            N:    4098600    S:    3881670   Res:    30
 |            E:     449130    W:     207600   Res:    30
 |   Range of data:    min = 35.03556  max = 37
r.info longitud:
 |   Data Type:    FCELL
 |   Rows:         7231
 |   Columns:      8051
 |   Range of data:    min = 99.55805  max = 102.285
Any idea how I can solve this problem?
Thank you!
View this message in context: http://osgeo-org.1560.n6.nabble.com/error-in-r-sun-with-latin-and-longin-maps-tp4984349.html
Sent from the Grass - Users mailing list archive at Nabble.com.
