[GRASS-user] compiling Add-Ons in Mac OS X
Carlos Grohmann carlos.grohmann at gmail.com
Tue Mar 13 12:07:55 EDT 2012
Hello all,
on an unrelated topic to my issues with wxgui and wx2.9, I'm also facing
some problems with add-ons.
Specifically, I need r.stream.order.
So I compile GRASS 7.0svn, and it goes fine. Here's my config options:
export CFLAGS="-O2"
export CXXFLAGS=""
export LDFLAGS=""
./configure \
--enable-largefile \
--prefix=/Applications \
--enable-macosx-app \
--enable-sysv \
--without-glw \
--without-motif \
--without-cairo \
--without-geos \
--with-x \
--with-x-includes=/usr/X11R6/include \
--with-x-libraries=/usr/X11R6/lib \
--with-opengl=aqua \
--without-odbc \
--with-cxx \
--with-freetype \
--with-freetype-includes=/Library/Frameworks/FreeType.framework/unix/include
--with-freetype-libs=/Library/Frameworks/FreeType.framework/unix/lib \
--with-gdal=/Library/Frameworks/GDAL.framework/Versions/1.8/Programs/gdal-config
--with-proj-includes=/Library/Frameworks/PROJ.framework/unix/include \
--with-proj-libs=/Library/Frameworks/PROJ.framework/unix/lib \
--with-proj-share=/Library/Frameworks/PROJ.framework/Versions/4.6/unix/share/proj
--with-jpeg \
--with-jpeg-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
--with-jpeg-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib \
--with-tiff \
--with-tiff-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
--with-tiff-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib \
--with-png-includes=/Library/Frameworks/UnixImageIO.framework/unix/include \
--with-png-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib \
--with-sqlite \
--with-sqlite-libs=/Library/Frameworks/SQLite3.framework/unix/lib \
--with-sqlite-includes=/Library/Frameworks/SQLite3.framework/unix/include \
--without-fftw \
--with-postgres-includes=/usr/local/pgsql/include \
--with-postgres-libs=/usr/local/pgsql/lib \
--with-freetype \
--with-python=/Library/Frameworks/Python.framework/Versions/2.7/bin/python-config
--with-wxwidgets=/usr/local/lib/wxPython-2.9.3.1/bin/wx-config \
--without-readline \
--without-tcltk \
--with-blas \
--with-lapack \
--with-blas-includes=/System/Library/Frameworks/Accelerate.framework/Frameworks/vecLib.framework/Headers
--with-lapack-includes=/System/Library/Frameworks/Accelerate.framework/Frameworks/vecLib.framework/Headers
I run make, make libs, and make install, which creates my GRASS-7.0.app in
/Applications
Then I get the add-ons from svn as
svn checkout http://svn.osgeo.org/grass/grass-addons
I cd into r.stream.order and try this:
make MODULE_TOPDIR=/Users/guano/Documents/installs/grass/grass_trunk/
and get this:
GuanoMac:r.stream.order guano$ make
: && gcc
-L/Users/guano/Documents/installs/grass/grass_trunk/dist.x86_64-apple-darwin11.3.0/lib
   -o
/Users/guano/Documents/installs/grass/grass_trunk/dist.x86_64-apple-darwin11.3.0/bin/r.stream.order
OBJ.x86_64-apple-darwin11.3.0/io.o OBJ.x86_64-apple-darwin11.3.0/main.o
OBJ.x86_64-apple-darwin11.3.0/stream_init.o
OBJ.x86_64-apple-darwin11.3.0/stream_order.o
OBJ.x86_64-apple-darwin11.3.0/stream_raster_close.o
OBJ.x86_64-apple-darwin11.3.0/stream_topology.o
OBJ.x86_64-apple-darwin11.3.0/stream_vector.o    -lgrass_gis.7.0.svn
-lgrass_raster.7.0.svn -lgrass_segment.7.0.svn  -lgrass_dbmiclient.7.0.svn
-lgrass_dbmibase.7.0.svn
Undefined symbols for architecture x86_64:
  "_Vect_new_line_struct", referenced from:
      _ram_create_vector in stream_vector.o
      _seg_create_vector in stream_vector.o
  "_Vect_new_cats_struct", referenced from:
  "_Vect_open_new", referenced from:
  "_Vect_reset_line", referenced from:
  "_Vect_reset_cats", referenced from:
  "_Vect_cat_set", referenced from:
  "_Vect_append_point", referenced from:
  "_Vect_write_line", referenced from:
  "_Vect_hist_command", referenced from:
  "_Vect_build", referenced from:
  "_Vect_close", referenced from:
  "_Vect_default_field_info", referenced from:
      _stream_add_table in stream_vector.o
  "_Vect_subst_var", referenced from:
  "_Vect_map_add_dblink", referenced from:
ld: symbol(s) not found for architecture x86_64
collect2: ld returned 1 exit status
make: ***
[/Users/guano/Documents/installs/grass/grass_trunk/dist.x86_64-apple-darwin11.3.0/bin/r.stream.order]
Error 1
So, now I'm having problems with 64bits?
thanks
Carlos
Prof. Carlos Henrique Grohmann - Geologist D.Sc.
Institute of Geosciences - Univ. of São Paulo, Brazil
http://www.igc.usp.br/pessoais/guano
http://www.igc.usp.br/openstereo<http://www.igc.usp.br/index.php?id=openstereo>
http://lattes.cnpq.br/5846052449613692 (CV)
Twitter: @CarlosGrohmann
http://carlosgrohmann.tumblr.com/
________________
Can’t stop the signal.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120313/a98c6fa6/attachment.html
