[GRASS-user] About Flood, Erosion and hydrological modelling
Venkatesh Raghavan raghavan at media.osaka-cu.ac.jp
Fri Mar 23 04:35:34 EDT 2012
Dear All,
Doing a bit of work with tram in Vietnam using HEC-RAS and
HEC-GeoRAS. It would be nice to have a GRASS interface to
HEC-RAS. HEC-GeoRAS below is an interface for ArcGIS.
Perhaps a project for some student or Google Summer of Code?
HEC-RAS
http://www.hec.usace.army.mil/software/hec-ras/
HEC-GeoRAS
http://www.hec.usace.army.mil/software/hec-ras/hec-georas.html
I have also included some other modelling tools related to
flood/hydrology, erosion etc. Perhaps you know most of it already.
In future, it may be world considering
how some of these models can be put to work together to
bring out more comprehensive output of physical processes.
For example there is already some work on integrating HEC-RAS with
MODFLOW.
https://publicwiki.deltares.nl/display/OPENMI/Workshops+on+integration+of+the+HEC-RAS+and+MODFLOW+models+using+OpenMI
Fully conservative coupling of HEC-RAS with MODFLOW to simulate
stream–aquifer interactions in a drainage basin
http://www.sciencedirect.com/science/article/pii/S0022169408000772
Surface Water-Groundwater Software Coupling
http://www.groundwater-conference.uci.edu/files/Chapter4/2008_conf_Fenske,%20J.pdf
Development of integrated MODFLOW HEC-RAS model using OpenMI
http://code.google.com/p/rasmodflow/
Flood/Hydrological Modelling
ICHARM, Japan
http://www.icharm.pwri.go.jp/
Integrated Flood Analysis System (IFAS)
http://www.icharm.pwri.go.jp/research/ifas/index.html
BASINS (Better Assessment Science Integrating point & Non-point Sources)
http://water.epa.gov/scitech/datait/models/basins/index.cfm
Kinematic runoff and erosion model KINEROS
http://www.tucson.ars.ag.gov/kineros/
GIS and Distributed Watershed Models II
http://digitalcommons.unl.edu/cgi/viewcontent.cgi?article=1466&context=usdaarsfacpub&sei-redir=1&referer=http%3A%2F%2Fwww.google.com%2Furl%3Fsa%3Dt%26rct%3Dj%26q%3Dhec-ras%2520grass%2520gis%26source%3Dweb%26cd%3D6%26ved%3D0CEYQFjAF%26url%3Dhttp%253A%252F%252Fdigitalcommons.unl.edu%252Fcgi%252Fviewcontent.cgi%253Farticle%253D1466%2526context%253Dusdaarsfacpub%26ei%3DO31mT5j_H_HsmAWtw4G5CA%26usg%3DAFQjCNEyfNWNrpn8XB73bGz8lAN8ZipR2A#search=%22hec-ras%20grass%20gis%22
Best
Venka
