[GRASS-user] About Flood, Erosion and hydrological modelling
Venkatesh Raghavan raghavan at media.osaka-cu.ac.jp
Sat Mar 24 08:05:26 EDT 2012
Hi Wolf,
HEC-GeoRAS is used to prepare data inputs for HEC-RAS.
I do not see any need to modify GRASS to prepare such
input. It would need developing some new modules (and wxGUI)
using GRASS Libraries.
BTW, today http://www.hec.usace.army.mil/ seems to be down.
Best
Venka
On 2012/03/24 4:50, Wolf Bergenheim wrote:
> Hi Venka,
> That seems to an interesting thing. I find it especially interesting since
> it's from the same people who originally developed GRASS. Perhaps they
> would be willing to co-mentor. Anyways Venka, do you have any information
> on how it works together with ARC? I mean would it be possible to get it to
> work with GRASS without modifying anything but GRASS?
> --Wolf
> On Fri, Mar 23, 2012 at 09:35, Venkatesh Raghavan<
> raghavan at media.osaka-cu.ac.jp>  wrote:
>> Dear All,
>> Doing a bit of work with tram in Vietnam using HEC-RAS and
>> HEC-GeoRAS. It would be nice to have a GRASS interface to
>> HEC-RAS. HEC-GeoRAS below is an interface for ArcGIS.
>> Perhaps a project for some student or Google Summer of Code?
>> HEC-RAS
>> http://www.hec.usace.army.mil/**software/hec-ras/<http://www.hec.usace.army.mil/software/hec-ras/>
>> HEC-GeoRAS
>> http://www.hec.usace.army.mil/**software/hec-ras/hec-georas.**html<http://www.hec.usace.army.mil/software/hec-ras/hec-georas.html>
>> I have also included some other modelling tools related to
>> flood/hydrology, erosion etc. Perhaps you know most of it already.
>> In future, it may be world considering
>> how some of these models can be put to work together to
>> bring out more comprehensive output of physical processes.
>> For example there is already some work on integrating HEC-RAS with
>> MODFLOW.
>> https://publicwiki.deltares.**nl/display/OPENMI/Workshops+**
>> on+integration+of+the+HEC-RAS+**and+MODFLOW+models+using+**OpenMI<https://publicwiki.deltares.nl/display/OPENMI/Workshops+on+integration+of+the+HEC-RAS+and+MODFLOW+models+using+OpenMI>
>> Fully conservative coupling of HEC-RAS with MODFLOW to simulate
>> stream–aquifer interactions in a drainage basin
>> http://www.sciencedirect.com/**science/article/pii/**S0022169408000772<http://www.sciencedirect.com/science/article/pii/S0022169408000772>
>> Surface Water-Groundwater Software Coupling
>> http://www.groundwater-**conference.uci.edu/files/**
>> Chapter4/2008_conf_Fenske,%**20J.pdf<http://www.groundwater-conference.uci.edu/files/Chapter4/2008_conf_Fenske,%20J.pdf>
>> Development of integrated MODFLOW HEC-RAS model using OpenMI
>> http://code.google.com/p/**rasmodflow/<http://code.google.com/p/rasmodflow/>
>> Flood/Hydrological Modelling
>> ICHARM, Japan
>> http://www.icharm.pwri.go.jp/
>> Integrated Flood Analysis System (IFAS)
>> http://www.icharm.pwri.go.jp/**research/ifas/index.html<http://www.icharm.pwri.go.jp/research/ifas/index.html>
>> BASINS (Better Assessment Science Integrating point&  Non-point Sources)
>> http://water.epa.gov/scitech/**datait/models/basins/index.cfm<http://water.epa.gov/scitech/datait/models/basins/index.cfm>
>> Kinematic runoff and erosion model KINEROS
>> http://www.tucson.ars.ag.gov/**kineros/<http://www.tucson.ars.ag.gov/kineros/>
>> GIS and Distributed Watershed Models II
>> http://digitalcommons.unl.edu/**cgi/viewcontent.cgi?article=**
>> 1466&context=usdaarsfacpub&**sei-redir=1&referer=http%3A%**
>> 2F%2Fwww.google.com%2Furl%**3Fsa%3Dt%26rct%3Dj%26q%3Dhec-**
>> ras%2520grass%2520gis%**26source%3Dweb%26cd%3D6%26ved%**
>> 3D0CEYQFjAF%26url%3Dhttp%253A%**252F%252Fdigitalcommons.unl.**
>> edu%252Fcgi%252Fviewcontent.**cgi%253Farticle%253D1466%**
>> 2526context%253Dusdaarsfacpub%**26ei%3DO31mT5j_H_HsmAWtw4G5CA%**26usg%**
>> 3DAFQjCNEyfNWNrpn8XB73bGz8lAN8**ZipR2A#search=%22hec-ras%**
>> 20grass%20gis%22<http://digitalcommons.unl.edu/cgi/viewcontent.cgi?article=1466&context=usdaarsfacpub&sei-redir=1&referer=http%3A%2F%2Fwww.google.com%2Furl%3Fsa%3Dt%26rct%3Dj%26q%3Dhec-ras%2520grass%2520gis%26source%3Dweb%26cd%3D6%26ved%3D0CEYQFjAF%26url%3Dhttp%253A%252F%252Fdigitalcommons.unl.edu%252Fcgi%252Fviewcontent.cgi%253Farticle%253D1466%2526context%253Dusdaarsfacpub%26ei%3DO31mT5j_H_HsmAWtw4G5CA%26usg%3DAFQjCNEyfNWNrpn8XB73bGz8lAN8ZipR2A#search=%22hec-ras%20grass%20gis%22>
>> Best
>> Venka
>> ______________________________**_________________
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/**mailman/listinfo/grass-user<http://lists.osgeo.org/mailman/listinfo/grass-user>
