[GRASS-user] Displaying site_name on r.watershed output basins map
Margherita Di Leo diregola at gmail.com
Tue May 1 09:55:43 EDT 2012
Rich,
On Tue, May 1, 2012 at 3:47 PM, Rich Shepard <rshepard at appl-ecosys.com>wrote:
> On Tue, 1 May 2012, Margherita Di Leo wrote:
>  This is weird. Which is the exact command line you used? should be
>> something like:
> Madi,
>  I used the GUI; will try again with the command line (my preference,
> anyway).
Using the GUI, you can check the correspondent command line displayed in
the bottom part of the command window.
>  r.to.vect input=basins output=basins feature=area
>  I used a different output name, but did specify area as the feature.
This doesn't affect the result at all, it was just for example.
>  Once you have that, you can use v.label to display labels, and calculate
>> the area using v.db.addcol + v.to.db
>  Didn't do this ... but I will. This is good information for me.
>  I also confirmed that r.basin calculates area as part of its output.
> Many thanks,
You are welcome
madi
> Rich
> ______________________________**_________________
> grass-user mailing list
> http://lists.osgeo.org/**mailman/listinfo/grass-user<http://lists.osgeo.org/mailman/listinfo/grass-user>
Ing. Margherita Di Leo, Ph.D.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120501/68926f72/attachment.html
