[GRASS-user] Displaying site_name on r.watershed output basins map
Margherita Di Leo diregola at gmail.com
Wed May 2 16:49:39 EDT 2012
Rich,
On Wed, May 2, 2012 at 3:52 PM, Rich Shepard <rshepard at appl-ecosys.com>wrote:
> On Wed, 2 May 2012, Micha Silver wrote:
>  Have a look that you've enabled displaying of an attribute column. In the
>> GUI, it's on the "Required" tab as "Display selected attribute based on
>> attrcol". On the CLI "d.vect disp=shape,attr " This always trips me up
>> also. Should be a FAQ. And perhaps the "Display attribute..." should get
>> enabled somehow automatically whenever an attribute column for labeling is
>> chosen.
> Micha,
>  I saw that before I wrote for help, but checking the attribute checkbox
> makes no difference. I cannot display either the cat numbers nor the
> raster map site_name which is the value column in the vector table.
>  When I uncheck all features but area the display clears. I have to try
> various options before the boundaries re-appear.
>  From the command line, writing to d.mon x0:
> GRASS 6.5.svn :~/grassdata > d.vect map=basinv disp=shape,attr type=area
> fcolor=none attrcol=value
what does v.info map=basinv say?
Ing. Margherita Di Leo, Ph.D.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120502/013d2f03/attachment.html
