[GRASS-user] help..
Markus Neteler neteler at osgeo.org
Wed May 2 17:16:41 EDT 2012
On Sat, Apr 28, 2012 at 11:40 PM, Albert Saribekyan
<albertsaribekyan at rambler.ru> wrote:
>> /usr/lib/libproj.so
>> /usr/lib64/libproj.so
This indicates that you have both the 32bit and 64bit version of PROJ4
installed. Not necessarily a problem but you need to check if the
right version is used.
>> Scientific Linux SL release 5.5 (Boron)
I am also using Scientific Linux, so that should be fine.
Note: you can get all including GRASS as RPMs from here
http://wiki.osgeo.org/wiki/Enterprise_Linux_GIS
-> ELGIS repositories
This would bring also GRASS 6.4.2 to you.
Markus
Markus
