[GRASS-user] r.watershed MFD strange basin
ivan marchesini ivan.marchesini at gmail.com
Wed May 9 03:19:48 EDT 2012
Dear Markus,
thank you for your answer.
> Please report if the stream segments are as expected, because the
> determination of half-basins and basins is based on the stream
> segments.
this is the map of streams:
http://imageshack.us/photo/my-images/232/streams.png/
it seems fine..
> If the stream segments seem out of place, something is wrong with the
> identification of stream segments and you will need to look at flow
> accumulation and check if that makes sense.
this is the accumulation map:
http://imageshack.us/photo/my-images/37/accumulation.png/
the same as above...
> If the stream segments seem to be ok, something is wrong with
> determining the left and right side of a stream.
this is the map of basins:
http://imageshack.us/photo/my-images/11/basins.png/
these are the half_basins:
http://imageshack.us/photo/my-images/4/halfbasins.png/
As you can see the problem arises for the half_basins and not only in
one place. There are a lot of problems all around.
I cannot explain which is the reason of this behaviour..
if you like I can send you the DEM....
ciao
Ivan
Ti prego di cercare di non inviarmi files .dwg, .doc, .xls, .ppt.
Preferisco formati liberi.
Please try to avoid to send me .dwg, .doc, .xls, .ppt files.
I prefer free formats.
http://it.wikipedia.org/wiki/Formato_aperto
http://en.wikipedia.org/wiki/Open_format
Ivan Marchesini
Perugia (Italy)
Socio fondatore GFOSS "Geospatial Free and Open Source Software" http://www.gfoss.it
e-mail: ivan.marchesini at irpi.cnr.it
fax (mailfax): +39 1782092534
jabber: geoivan73 at jabber.org
skype: geoivan73
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20120509/84933de0/attachment-0001.bin
