[GRASS-user] v.buffer database error
Markus Neteler neteler at osgeo.org
Wed May 9 17:32:34 EDT 2012
On Wed, May 9, 2012 at 5:29 PM, Falko Engel <falko.engel at web.de> wrote:
> Dear list,
> I had a strange behavior of v.buffer today:
> v.buffer input=mydata output=mydata_buf bufcolumn=my_buf_col
> results in an error:
> "DBMI-Postgres driver error:
> Cannot select:
> SELECT cat, my_buf_col FROM mydata"
> However, if I copy the exact statement of the error message into
> echo "SELECT cat, my_buf_col FROM mydata" | db.select
> the result is fine!
You could set this:
g.gisenv set=DEBUG=3
then relaunch the command to see if the more detailed output contains
relevant pieces (to post here, not all please :-).
To disable debug output, use
g.gisenv set=DEBUG=0
Markus
> I'm using the following setup:
> Opensuse 11.3, GRASS GIS 6.4.2
> My attribute tables are stored in a Postgres DB which is located on a
> network server.
> All other DB operations in GRASS are fine.
> Falko
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
