Re: [GRASS-user] XYZ Data (UTM32N) workflow to DEM and reprojection to Gauß Krüger 3
Moritz Lennert mlennert at club.worldonline.be
Mon May 14 05:18:38 EDT 2012
On 14/05/12 10:42, Danny Luque Ramirez wrote:
> Hi list,
> I'm trying to calculate a DEM out of my XYZ data. After the calculation I
> need to transform the projection to EPSG: 31467. Does GRASS offer a good
> workflow for this?
Yes.
If you are unfamiliar with GRASS, you might want to start here:
http://grass.osgeo.org/intro/firsttime.php
http://grass.osgeo.org/grass64/manuals/html64_user/helptext.html
http://grass.osgeo.org/wiki/GRASS_Help#First_Day_Documentation (although
I can't connect to the wiki currently)
More detailed info for your question here:
http://grass.fbk.eu/grass64/manuals/html64_user/rasterintro.html
http://grass.fbk.eu/grass64/manuals/html64_user/projectionintro.html
Two modules you might be specifically interested in:
import (depending on the exact format of your data): r.in.gdal,
r.in.xyz, r.in.bin
reprojection: r.proj
In brief, you have to:
- create two locations, one with the original projection of your data
and one in the 31467 projection
- import your data into the first location
- enter into the second location and reproject using r.proj
Moritz
