[GRASS-user] Calculate stream order from digitized hydrology network
Filipe Silva Dias filipesdias at gmail.com
Mon May 14 09:53:25 EDT 2012
Hi Johannes
Yes, its in vector format, but it could be converted to raster if necessary.
I installed v.strahler with g.extension, but loading it produced an error.
Is there another one?
Thanks
  File "C:\OSGeo4W\apps\grass\grass-6.4.2\etc\wxpython\gui_m
odules\prompt.py", line 1105, in OnKeyPressed
self.parent.RunCmd(cmd)
odules\goutput.py", line 523, in RunCmd
task = menuform.GUI(show = None).ParseCommand(command)
odules\menuform.py", line 1732, in ParseCommand
blackList = _blackList)
  File "C:\OSGeo4W\apps\grass\grass-6.4.2\etc\python\grass\s
cript\task.py", line 460, in parse_interface
tree = etree.fromstring(get_interface_description(name))
  File
"C:\OSGeo4W\apps\Python27\lib\xml\etree\ElementTree.py",
line 1283, in XML
return parser.close()
  File
line 1636, in close
self._raiseerror(v)
  File
line 1488, in _raiseerror
raise err
xml.etree.ElementTree
ParseError
no element found: line 1, column 0
On Mon, May 14, 2012 at 2:47 PM, Johannes Radinger <jradinger at gmx.at> wrote:
> Hi Filipe,
> you mean your hydrological network is in vector format?
> Maybe you  can try the v.strahler add-on but I don't know
> how uptodate this module is:
> http://grass.osgeo.org/wiki/GRASS_AddOns#v.strahler
> /johannes
> Am 14.05.2012 um 13:26 schrieb Filipe Silva Dias:
> > Dear all,
> > I have a digitized hydrological network and I need to calculate the
> stream order (Horton, Strahler etc).
> > I found r.stream.order but it requires that the hydrological network
> comes from a DEM, which in my case produced an hydrological network that is
> considerably different than the digitized one (tried both with r.wateshed,
> r.terraflow and r.stream.extract).
> > Is there a tool capable of doing this? Apparently ArcGIS can do this,
> but id prefer na open source solution.
> > Thanks
> > Best regards
> > Filipe
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120514/0c07e641/attachment.html
