[GRASS-user] Calculate stream order from digitized hydrology network
Margherita Di Leo diregola at gmail.com
Tue May 15 06:39:21 EDT 2012
Hi Filipe,
could you fill a bug report reporting this? Thanks
Best,
madi
On Mon, May 14, 2012 at 3:53 PM, Filipe Silva Dias <filipesdias at gmail.com>wrote:
> Hi Johannes
> Yes, its in vector format, but it could be converted to raster if
> necessary.
> I installed v.strahler with g.extension, but loading it produced an error.
> Is there another one?
> Thanks
> Traceback (most recent call last):
>   File "C:\OSGeo4W\apps\grass\grass-6.4.2\etc\wxpython\gui_m
> odules\prompt.py", line 1105, in OnKeyPressed
> self.parent.RunCmd(cmd)
> odules\goutput.py", line 523, in RunCmd
> task = menuform.GUI(show = None).ParseCommand(command)
> odules\menuform.py", line 1732, in ParseCommand
> blackList = _blackList)
>   File "C:\OSGeo4W\apps\grass\grass-6.4.2\etc\python\grass\s
> cript\task.py", line 460, in parse_interface
> tree = etree.fromstring(get_interface_description(name))
>   File
> "C:\OSGeo4W\apps\Python27\lib\xml\etree\ElementTree.py",
> line 1283, in XML
> return parser.close()
>   File
> line 1636, in close
> self._raiseerror(v)
>   File
> line 1488, in _raiseerror
> raise err
> xml.etree.ElementTree
> ParseError
> no element found: line 1, column 0
> On Mon, May 14, 2012 at 2:47 PM, Johannes Radinger <jradinger at gmx.at>wrote:
>> Hi Filipe,
>> you mean your hydrological network is in vector format?
>> Maybe you  can try the v.strahler add-on but I don't know
>> how uptodate this module is:
>> http://grass.osgeo.org/wiki/GRASS_AddOns#v.strahler
>> /johannes
>> Am 14.05.2012 um 13:26 schrieb Filipe Silva Dias:
>> > Dear all,
>> > I have a digitized hydrological network and I need to calculate the
>> stream order (Horton, Strahler etc).
>> > I found r.stream.order but it requires that the hydrological network
>> comes from a DEM, which in my case produced an hydrological network that is
>> considerably different than the digitized one (tried both with r.wateshed,
>> r.terraflow and r.stream.extract).
>> > Is there a tool capable of doing this? Apparently ArcGIS can do this,
>> but id prefer na open source solution.
>> > Thanks
>> > Best regards
>> > Filipe
>> > _______________________________________________
>> > grass-user mailing list
>> > grass-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/grass-user
Ing. Margherita Di Leo, Ph.D.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120515/84db6a18/attachment-0001.html
