[GRASS-user] Re: Problem with r.stream.order
Markus Neteler neteler at osgeo.org
Thu May 17 16:45:19 EDT 2012
On Mon, May 14, 2012 at 4:59 PM, Marcello Benigno
<benigno.marcello at gmail.com> wrote:
> I tested in both Ubuntu and GRASS 32bits and works fine, so the problem is
> only in the 64bits version.
> 2012/5/13 Marcello Benigno <benigno.marcello at gmail.com>
>> GRASS 6.5.svn (Litoral):~ > r.stream.order stream=streams dir=dirs
>> strahler=streams_strahler shreve=streams_shreve horton=streams_horton
>> hack=streams_hack topo=streams_topo table=tb_order
>> DBMI-SQLite driver error:
>> Error in sqlite3_prepare():
>> no such column: inf
>> ERROR: Cannot inset new row: insert into tb_order values (2, 2, -1, 0 ,0,
>>        0, 1, 1, 1, 1, 1, 30.001727, 30.001727 , 30.001727, 0.000000, inf)
could you please provide a North Carolina example for easy
replication?
thanks
Markus
