[GRASS-user] opening dbf tables
    ricerca
    ricerca at palombini.net
    Fri May 18 11:07:46 EDT 2012
Dear all,
as i'm not very used used to work on vector files i don't know how to manage a (probably) simple problem.i'm working on some shapefiles to be imported in Grass, but before doing so i should modify the dbf table. When trying to open it (Ubuntu 12.04), i got the message
(in italian)
errore generale errore generale di I/O
i wasn't able to pen the table even by command line (sudo) nor found any hidden lock file in the directory.
Any suggestion?Thanks a lot
Augusto
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120518/e1ce9574/attachment.html
