[GRASS-user] GRASS region corruption
Hermann Peifer peifer at gmx.eu
Sat May 26 20:02:48 PDT 2012
On 26/05/2012 20:26, spiderplant0 wrote:
> Does anyone know where what file the region is set in? I.e. is there some
> file I can delete to reset it.
Look for a file named WIND, in the given mapset.
I was about to point you to [1], then I noted that this page tells you
the name of the default region (PERMANENT/DEFAULT_WIND), the location of
saved regions (in a given mapset, under the windows directory) but
doesn't tell you that WIND keeps the values of the current region.
Hermann
[1] http://grass.osgeo.org/grass64/manuals/html64_user/g.region.html
