[GRASS-user] v.dissolve renames the attribute column
Markus Metz markus.metz.giswork at googlemail.com
Sun May 27 14:26:56 PDT 2012
On Sun, May 27, 2012 at 2:38 PM, spiderplant0 <spiderplant0 at gmail.com> wrote:
> When I run v.dissolve on my vector...
> *v.dissolve --o input=pass2 at mapset1 layer=1 column=fttcp output=pass3*
> The dissolving appears to work but the column name in the attribute table
> has changed from 'fttcp' to 'cat'. (I can tell by loading the GRASS vector
> into QGIS and viewing the attribute table).
Do you mean the column name of the input vector changed?
> Also, although the input has a dbf file, the output does not.
If the column is integer or not specified, there is no need for a new
attribute table because the new categories are either the same like
the old categories or identical to the values in <column>. You could
dun v.db.addtable in order to get an attribute table, but that does
not add any new information.
Markus M
> Is there a way to tell v.dissolve to retain the original column name or is
> there a way to rename it?
> Also, is there a reason v.dissolve doesnt write a dbf. Is there a way to get
> it to write the attribute table to a dbf or is there a way to convert the
> vector so it uses a dbf?
> I am using GRASS 6.4.2 on windows 7
> View this message in context: http://osgeo-org.1560.n6.nabble.com/v-dissolve-renames-the-attribute-column-tp4977208.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
