[GRASS-user] Identifying Why Vector Map Lables Do Not Display
Nick Jachowski njachowski at gmail.com
Mon May 28 03:08:10 PDT 2012
Hi Rich,
I've had this problem before and for me it always seemed to be an issue of
setting the size of labels correctly, which can be tricky sometimes,
particularly if your location is latlong (if I remember correctly the size
is in map units, so in that case you need to compute your desired label
size as degrees).
It's been a while since I've had to do this though, so I'm not 100% certain
of this, but perhaps it will solve your problem.
Best,
Nick
On Mon, May 28, 2012 at 4:43 AM, Rich Shepard <rshepard at appl-ecosys.com>wrote:
>  I've a vector map of areas created from the raster original using
> r.to.vect with the '-v' option. The vector map's attribute table has cat
> values which is sufficient for me to identify specific polygons. However,
> when displaying the map the lables do not appear despite the attr and cat
> options being selected.
>  What procedure will allow me to identify why the labels don't display so I
> can fix the problem?
> Rich
> ______________________________**_________________
> grass-user mailing list
> http://lists.osgeo.org/**mailman/listinfo/grass-user<http://lists.osgeo.org/mailman/listinfo/grass-user>
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20120528/ee949c3e/attachment.html>
