[GRASS-user] Report from ongoing GRASS GIS Community Sprint in Prague
Markus Metz markus.metz.giswork at googlemail.com
Mon May 28 06:08:42 PDT 2012
On Mon, May 28, 2012 at 2:47 PM, Paolo Cavallini <cavallini at faunalia.it> wrote:
> Il 28/05/2012 14:33, Benjamin Ducke ha scritto:
>> SEXTANTE and gvSIG CE share a bug tracker
>> at http://bugs.gvsigce.org, a decision that
>> was made together with Victor Olaya a while
> Hi all.
> Sorry for the misunderstanding.
> I am not sure Victor (main SEXTANTE dev, AFAIK) is listening here - if so, he can
> explain much better.
> Anyway, I (and I suspect also Marckus) was referring to the QGIS Python plugin called
> sextante. No shared code with the Java version, AFAIK.
I have just compared the QGIS SEXTANTE plugin, the gvSIG SEXTANTE
plugin, and the generic SEXTANTE. For example, the contents of the
grass/description folder of QGIS SEXTANTE are completely different
from gvSIG and generic SEXTANTE. The former has hand-crafted .txt
files, the latter have automatically generated (<grass command>
--interface-description) XML files. QGIS SEXTANTE is pure python
without any java code, the others are pure java without any python
code.
There is a dedicated bug tracker for QGIS SEXTANTE, and from a user
perspective this is the logical place to report issues for QGIS
SEXTANTE, in particular when keeping in mind that the GRASS command
interfaces in QGIS SEXTANTE are hand-crafted, see v.buffer.angle.txt,
v.buffer.column.txt, v.buffer.distance.txt,
v.buffer.minordistance.txt, four different interfaces to the same
GRASS command v.buffer. In gvSIG SEXTANTE, there is only v.buffer.xml.
How should a user take these differences into account? Report to
http://bugs.gvsigce.org and explain that this does not apply to gvSIG
SEXTANTE, only to QGIS SEXTANTE?
Markus M
