[GRASS-user] Fwd: Re: [Qgis-developer] Sextante: v.buffer angle does not work
Paolo Cavallini cavallini at faunalia.it
Wed May 30 09:44:34 PDT 2012
FYI.
Thanks.
-------- Messaggio originale --------
Oggetto: Re: [Qgis-developer] Sextante: v.buffer angle does not work
Data: Wed, 30 May 2012 18:33:19 +0200
Mittente: Victor Olaya <volayaf at gmail.com>
A: cavallini at faunalia.it
CC: qgis-developer <qgis-developer at lists.osgeo.org>
mmmm, I had splitted it, and in fact this algorithm just calls the
angle option, but it still complains
This is your command line
v.buffer input=tmp1338388935286 angle=90 tolerance=0.01 -s -c
output=output --overwrite
and it says
ERRORE: Select a buffer distance/minordistance/angle or column, but not
       both.
But it's only passing an angle, not any of the other options!!!. Or
you are not supposed to use tolerance with the angle option?
Any GRASS expert can help?
