[GRASS-user] installing Grass 7 on ubuntu 11.04
Manish Gautam manish.gautam29 at gmail.com
Sat Nov 3 02:56:42 PDT 2012
Thanks again. This time I am getting the following problems :
1. So, when I run ./configure after installing Proj 4, GEOS and GDAL,
this error comes
checking for tcl.h... no
configure: error: *** Unable to locate Tcl includes.
2.and using this
--with-tcltk-includes="/usr/include/tcl8.5/"
It shows the following message:
"checking for location of Tcl/Tk includes... /usr/include/tcl8.5/
configure: error: *** Tcl/Tk includes directory /usr/include/tcl8.5/
does not exist. "
3. do I need to run this "svn checkout
https://svn.osgeo.org/grass/grass/trunk" ?
it gives this message : " svn: OPTIONS of
'https://svn.osgeo.org/grass/grass/trunk': could not connect to server
(https://svn.osgeo.org) "
[is it because of the proxy in the internet connection I am using ? I
tired it several times but it never got connected.]
4. so I skipped the above step and instead downloaded the grass 7
source files and extracted it in the source directory. then i ran
./configure \ and got the following error
" checking whether to use FFMPEG... yes
checking for location of FFMPEG includes... /usr/include/libavcodec
/usr/include/libavformat /usr/include/libswscale
configure: error: *** FFMPEG includes directory
/usr/include/libavcodec does not exist. "
Thanks,
Regards.
On 2 November 2012 13:11, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On 1 November 2012 13:32, Manish Gautam <manish.gautam29 at gmail.com> wrote:
>> worked as I didn't use the ubuntu repository to install rest of the
>> prerequisites, but downloaded manually and moved to the source code
>> directory and then configured it accordingly
> Note that manual downloading and compiling of source codes is usually
> not necessary. Using packages from Ubuntu repository should be
> sufficient.
> If not you can use ubuntu-gis ppa repository. This is how you add it
> to your system:
> apt-get -y install python-software-properties
> add-apt-repository ppa:ubuntugis/ppa
> apt-get -y update
> But to be honest, now I'm not sure if this ppa repository, is really necessary.
> By the way, you may be interested also in this thread:
> http://osgeo-org.1560.n6.nabble.com/Please-update-quot-Compile-on-Ubuntu-quot-page-in-Wiki-td4999519.html
> Vaclav
