[GRASS-user] Is r.damflood is suitable for grass6.5
Roberto Marzocchi roberto.marzocchi at gmail.com
Thu Nov 8 02:38:52 PST 2012
r.dam is a simple bash script that is useful to create the data for
r.damflood.
Unfortunately r.dam is written in the grass 6 style and is needed to
convert it to use in grass 7, while r.damflood is written in C using the
grass7 libraries [1] so you don't find itr for grass6.5.
The error [2] depend on the absence of a makefile. I see that Markus add a
makefile this morning ( I also try to add it), I think that now you can
compile r.dam.
There is no description of r.dam, I will add as soon as possible.
Concerning r.damflood, you can find the codes in grass7/raster/r.damflood/
[1] and I think you can easily compile for Grass7. IYou cannot compile for
grass6.5, it is need a correction of libraries. I'm not an expert about it.
I did it manually to update r.damflood to grass7, but after we develop some
new functionalities and perform the debug on the grass7 version of
r.damflood, so I do not want to add the old code developed in for Grass 6.4
because I'm not sure about the correctness of it. We choose in fact to
develop it only for grass7 and I think it is reasonable.
Roberto
2012/11/8 Martin Landa <landa.martin a gmail.com>
> Hi,
> 2012/11/8 SWAPAN GHOSH <swap.ghsh a gmail.com>:
> > I am trying to compile source code in Mingw environment for r.damflood.
> But
> > I have a problem that some libary is missing in my environment. Can you
> > please send me the .exe file by remaning as r.damflood.txt. Is it run
> > succesfully in Grass6.5.
> all addons are automatically build for winGRASS. You can install them
> from the GUI (Settings -> Addons -> Install). The binaries are
> available at [1]. I didn't find r.damflood, just r.dam (which failed)
> [2].
> Martin
> [1] http://wingrass.fsv.cvut.cz/grass65/addons/
> [2] http://wingrass.fsv.cvut.cz/grass65/addons/logs/r.dam.log
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
Un allegato HTML ? stato rimosso...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121108/dddfb434/attachment.html>
