[GRASS-user] Recent errors on GRASS6.4.2
Patrick S. patrick_GIS at gmx.ch
Thu Nov 15 02:47:07 PST 2012
I observe two errors in my GRASS-GIS 6.4.2 from UbuntuGIS-Repository
with sqlite as database. Does someone know whether these refer to
missing dependancies of UbuntuGIS or are errors of my system and - in
case of the latter - eventually how I can fix this?
1.) When starting GRASS I get the message: "3D view mode:
/usr/lib/grass64/lib/libgrass_ogsf.6.4.2.so: symbol TIFFSetField,
version GDAL_1.8 not defined in file libgdal.so.1 with link time
reference".
2.) When viewing attributes of a layer, I can identify it with the
query-tool, but get an empty table when selecting "show attribute data".
The shell will show a long list of packages, with the title "Memory
map", an extract of this is shown below. This does not happen for layers
imported from postgrsql, but for a layer that I imported from shapefile.
I also did reset the encoding, as this proofed to be an issue in the
query-selector, but that had no effect on the outcome of the
attribute-table.
Any help or hint would be very appreciated,
Patrick Schirmer
======= Memory map: ========
08048000-0804b000 r-xp 00000000 08:01 5899842
/usr/lib/grass64/bin/v.db.select
0804b000-0804c000 r--p 00002000 08:01 5899842
0804c000-0804d000 rw-p 00003000 08:01 5899842
09a99000-09aba000 rw-p 00000000 00:00 0          [heap]
b22e4000-b22e6000 rw-p 00000000 00:00 0
b22e6000-b22ed000 r--s 00000000 08:01 5268203
/usr/lib/i386-linux-gnu/gconv/gconv-modules.cache
b22ed000-b2322000 r--s 00000000 08:01 10627767 /var/cache/nscd/passwd
b2322000-b2453000 r--p 005b4000 08:01 3933787 /usr/lib/locale/locale-archive
b2453000-b2653000 r--p 00000000 08:01 3933787 /usr/lib/locale/locale-archive
b2653000-b2659000 rw-p 00000000 00:00 0
b2659000-b2661000 r-xp 00000000 08:01 2362970
/lib/i386-linux-gnu/libcrypt-2.15.so
b2661000-b2662000 r--p 00007000 08:01 2362970
b2662000-b2663000 rw-p 00008000 08:01 2362970
b2663000-b268b000 rw-p 00000000 00:00 0
b268b000-b26ce000 r-xp 00000000 08:01 5243463
/usr/lib/i386-linux-gnu/libhx509.so.5.0.0
b26ce000-b26cf000 ---p 00043000 08:01 5243463
b26cf000-b26d0000 r--p 00043000 08:01 5243463
b26d0000-b26d2000 rw-p 00044000 08:01 5243463
b26d2000-b26df000 r-xp 00000000 08:01 5243459
/usr/lib/i386-linux-gnu/libheimbase.so.1.0.0
b26df000-b26e0000 r--p 0000c000 08:01 5243459
b26e0000-b26e1000 rw-p 0000d000 08:01 5243459
b26e1000-b2708000 r-xp 00000000 08:01 5243461
/usr/lib/i386-linux-gnu/libwind.so.0.0.0
b2708000-b2709000 r--p 00027000 08:01 5243461
b2709000-b270a000 rw-p 00028000 08:01 5243461
b270a000-b271e000 r-xp 00000000 08:01 5243453
/usr/lib/i386-linux-gnu/libroken.so.18.1.0
b271e000-b271f000 r--p 00013000 08:01 5243453
b271f000-b2720000 rw-p 00014000 08:01 5243453
b2720000-b2752000 r-xp 00000000 08:01 5243457
/usr/lib/i386-linux-gnu/libhcrypto.so.4.1.0
b2752000-b2753000 r--p 00032000 08:01 5243457
b2753000-b2754000 rw-p 00033000 08:01 5243457
b2754000-b2756000 rw-p 00000000 00:00 0
