[GRASS-user] Improved version of r.fillnulls - needs quality check
Maris Nartiss maris.gis at gmail.com
Mon Nov 26 02:03:42 PST 2012
Hello all,
I just have commited to trunk (GRASS 7) a new version of r.fillnulls
that is filling each hole separately. On my test dataset it is giving
significantly better results than old one and provides ~2x speed up in
comparison with previous version (with a cost of increased disk use).
To see, if there aren't some corner cases where results got worse, I
kindly ask frequent r.fillnulls users to test most recent version
(after r54044) and report back any issues found. Differences should be
most visible if large NULL areas are present or input dataset is large
with NULLs located in different parts.
Thanks for helping to make GRASS the best GIS,
Maris.
