[GRASS-user] how to query a raster value
王德辉 dehuiw at gig.ac.cn
Tue Nov 27 23:37:10 PST 2012
It means the point value of the active raster layer is nodata(null). Please notice that only the active raster (left clicking the layer on the Map layers menu and it turning back ) can be queried when you use  query button. For example, if you added "lakes"and "elevation" raster layers (nc_spm dataset) and your active layer is lakes,but you want query the elevation by using the gui qurey button and you cilck the point outside the lakes, then the valu would be * .
May could help you!
dehui
在2012-11-28 06:15:58,王德辉<dehuiw at gig.ac.cn>写道:
> On Tue, Nov 27, 2012 at 4:21 PM, 侯伟 <houw11 at lzu.edu.cn> wrote:
> > in map display has a query button, i want to query a image value in a point
> > but get the below:
> > 489701.0583783784|4273345.954594594||*|
> > no value are displayed.  i think in grass there are category and cell can be
> > rater, does above are one type of this.
> To me it looks as if the position is in a NO DATA area ("*").
> > how can i change the type and query the value?
> Please double check the coordinates.
> Markus
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
