[GRASS-user] Can't load Grass 7 on Windows 7
Markus Neteler neteler at osgeo.org
Mon Oct 1 10:41:09 PDT 2012
On Sun, Sep 30, 2012 at 3:29 PM, Filipe Dias <filipesdias at gmail.com> wrote:
> Hi,
> I just installed Grass 7 via osgeo4w on W7 64 bits and got this error after
> pressing "Start Grass".
> 3d view mode: grass_g3d.7.0.svn not found
> Grass module g.region not found. Unable to star map display window
The package is coming from here:
http://wingrass.fsv.cvut.cz/grass70/osgeo4w/
In fact, there is a compilation error:
http://wingrass.fsv.cvut.cz/grass70/logs/log-r53294-363/error.log
--> /osgeo4w/usr/src/grass_trunk/lib/raster3d
Someone having a local Windows compile environment will need
to run "make" within the directory and check for the error. The
other errors will be mainly subsequent errors.
Markus
