[GRASS-user] Can't load Grass 7 on Windows 7
Martin Landa landa.martin at gmail.com
Mon Oct 1 14:31:53 PDT 2012
2012/10/1 Markus Neteler <neteler at osgeo.org>:
> In fact, there is a compilation error:
> http://wingrass.fsv.cvut.cz/grass70/logs/log-r53294-363/error.log
> --> /osgeo4w/usr/src/grass_trunk/lib/raster3d
see
http://wingrass.fsv.cvut.cz/grass70/logs/log-r53294-363/package.log
doubleio.c: In function `Rast3d_write_doubles':
doubleio.c:12: error: `u_int' undeclared (first use in this function)
doubleio.c:12: error: (Each undeclared identifier is reported only once
doubleio.c:12: error: for each function it appears in.)
doubleio.c:12: error: syntax error before "n"
doubleio.c:29: error: `n' undeclared (first use in this function)
doubleio.c: In function `Rast3d_read_doubles':
doubleio.c:54: error: `u_int' undeclared (first use in this function)
doubleio.c:54: error: syntax error before "n"
doubleio.c:71: error: `n' undeclared (first use in this function)
make[3]: *** [OBJ.i686-pc-mingw32/doubleio.o] Error 1
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
