[GRASS-user] vector export to DXF in 3d ?
"Peter Löwe" peter.loewe at gmx.de
Tue Oct 9 05:37:30 PDT 2012
Hi all,
how can a 3D vector in GRASS6.4  be exported into a DXF while preserving the 3D content ?
Example: Isohypses are created from the 10m DEM of the spearfish data set by r.contour.
v.info asserts that the newly created vector file is truly 3d. Also v.to.3d flatly refuses to work on the vector layer.
Alas, exporting the vector using v.to.dxf results in a perfectly "flat" DXF.
Does anybody of a good workaround for this one ?
Peter
Dr. Peter Löwe
<peter.loewe at gmx.de>
