[GRASS-user] r.shaded.relief
Patrick S. patrick_GIS at gmx.ch
Tue Oct 16 07:12:13 PDT 2012
Dear list,
I try to reproduce previous work reported in a paper done with the
hillshade-tool of ArcGIS, and am using GRASS64.
Comparing the hillshade of GRASS6.4, GDAL and ArcGIS showed that the
results vary- at least in terms of the resulting raster-values. While I
assume ArcGIS to create a local reference with values always reaching
from 0 to 255, GDAL and GRASS show different rastervalue-variances for
differing days. Does someone know if a comparison between those is
possible or whether a common method is implemented? Is there an option
implemented to standardize the values?
Syntax:
gdaldem hillshade ./dem_ktzh1.tif hillshade_gdal.tif -alt 14 -az 235
r.shaded.relief map=r_dem alt=14 azim=235 shaded=r_hillshade --o
Thank you for your help,
Patrick
