[GRASS-user] 6.5svn GUI Behavior Issue
Anna Kratochvílová kratochanna at gmail.com
Thu Oct 25 07:56:43 PDT 2012
On Thu, Oct 25, 2012 at 4:32 PM, Rich Shepard <rshepard at appl-ecosys.com> wrote:
>   I don't know if these two issues ought to be remedied since version 7.0
> seems to be the focus, but the devs should be aware of them in any case.
>   1) With the cursor in the Layer Manager the keyboard shortcut to open a
> vector layer (C-S-v) works as expected, but the shortcut to open a raster
> layer (C-S-r) does not. The latter brings up a dialog box informing that a
> raster map name needs to be provided in the dialog box. My response is
> always, "D'uh, that's what I want to do." Should be a simple fix; copy the
> vector dialog box invocation code.
Strange, it works for me (Ubuntu 10.04). The code seems to be the same
for raster and vector. What OS do you use?
>   2) When a vector map in the Layer Manager is selected (e.g., to alter
> display properties), the selection of the label column is lost. If that is
> not manually reselected the map will not display when the property box is
> closed.
I'm not sure about this, you should probably report a bug.
I found maybe related tickets:
http://trac.osgeo.org/grass/ticket/1749
http://trac.osgeo.org/grass/ticket/1605
http://trac.osgeo.org/grass/ticket/1604
Anna
> Rich
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
