[GRASS-user] Dam Failure & mapping of flood risk downstream
Thomas Adams thomas.adams at noaa.gov
Thu Oct 25 08:57:00 PDT 2012
Laurent,
Dambreak analysis is very complex, requiring a lot of in-channel
cross-section or bathymetric data and over-bank DEM data, as well as the
use of an unsteady hydraulic flow model such as the U.S. Army Corps of
Engineers, HEC-RAS model, which has this capability.
However, there are simplified techniques that can approximate detailed
analyses, such as:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&ved=0CCUQFjAA&url=http%3A%2F%2Fwww.hsdl.org%2F%3Fview%26did%3D8227&ei=rV-JUJGSGYjO0QHEw4BI&usg=AFQjCNHIGNVpLU5UZZ9ZuTfhi-tySFIs8w
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CCUQFjAA&url=http%3A%2F%2Famazon.nws.noaa.gov%2Farticles%2FHRL_Pubs_PDF_May12_2009%2FSeann_Reed%2FValidation_of_GeoSMPDBK_2011_07_22_submit_r2.pdf&ei=BWGJUNODNY6u0AHGlIDICQ&usg=AFQjCNGa3OsBOBVnYlWPKqsOgnBQKKN5Wg
Regards,
Tom
On Thu, Oct 25, 2012 at 10:33 AM, laurent celati <
lcelati at latitude-geosystems.com> wrote:
> Good afternoon,
> I have to simulate an artificial dam failure & mapping of flood risk
> downstream. I have already generate watershed file thanks to r.watershed.
> Now i want to mapping and calculate flood risk downstream (water level /
> volume /cubature) from a few available informations like charge,flow,etc.
> Could you throw light for me please? If you know other tools and algorithms
> that can help me in my study, don't hesitate.
> Thank you in advance.
> With kind regards.
> http://osgeo-org.1560.n6.nabble.com/Dam-Failure-mapping-of-flood-risk-downstream-tp5011263.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL:	thomas.adams at noaa.gov
VOICE:	937-383-0528
FAX:	937-383-0033
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121025/d2c7a506/attachment.html>
