[GRASS-user] G_malloc error
Benjamin Ducke benducke at fastmail.fm
Mon Oct 29 06:23:01 PDT 2012
Paul:
If you want GRASS to use more than 3.5GB of RAM,
then you need to run a 64 bit operating system.
Otherwise, no single application will get to see
more than 4GB. Also check your motherboard's manual
to see how much RAM it supports. Often, there are
limits of 16, 32 or 64GB total.
If you plan to use 64 bit Windows, then be aware
that Microsoft has put arbitrary limitations re.
usable RAM into each one of there many different
release versions. E.g. a Windows Home license might
not be able to use more than 8GB.
Ben
On 10/29/2012 02:19 PM, Paul Shapley wrote:
> Hi Users,
> I'm getting 'G_malloc' errors when using large images in Grass 6.4.3rc1.
> I need to use much larger images than the one causing the error. Is
> there a way around this problem? i have 3gb of RAM on this PC (standard
> MS Windows installer not osgeo). Is this enough RAM or should i invest
> in much more... or is there another cause of this?.
> Error message:
> Current region rows: 19998, cols: 15999
> ERROR: G_malloc: unable to allocate 1279792008 bytes of memory at gsds.c:575
> Paul J. Shapley
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Benjamin Ducke
{*} Geospatial Consultant
{*} GIS Developer
