[GRASS-user] Using r.out.kml and scripts in Windows Binary- error
Martin Landa landa.martin at gmail.com
Thu Sep 13 02:43:51 PDT 2012
2012/9/13 Martin Landa <landa.martin at gmail.com>:
> have you tried to install extension from command line or wxGUI [1]?
> wxGUI uses another g.extension (Python based) which should download on
> Windows directly prepared binaries.
to avoid user confusion, probably bash script `g.extension` should end
on Windows with an error, eg.
"g.extension is not working on MS Windows. Use wxGUI Extension Manager instead."
or similar...
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
