[GRASS-user] GDAL libgdal1.6.0.so.1 error (REPOST)
Markus Metz markus.metz.giswork at gmail.com
Mon Apr 22 03:28:11 PDT 2013
On Mon, Apr 22, 2013 at 10:59 AM, Santiago Timón <stimonmail at gmail.com> wrote:
> Hi Markus,
> I have removed the default ubuntu gdal installation using synaptic.
> administrador at torrevision:~$ sudo ldconfig -v | grep gdal
> /home/administrador/gdal192:
> libgdalconstjni.so.1 -> libgdalconstjni.so
> libgdal.so.1 -> libgdal.so.1.16.2
> libgdaljni.so.1 -> libgdaljni.so
> The symlinks in gdal folder:
> administrador at torrevision:~/gdal192$ ls -lah | grep ^l
> lrwxrwxrwx  1 root          root            18 abr 19 11:30
> lrwxrwxrwx  1 root          root            13 abr 19 11:30 libgdaljni.so.1
> -> libgdaljni.so
> lrwxrwxrwx  1 administrador administrador   17 abr  3 18:32 libgdal.so ->
> libgdal.so.1.16.2
> lrwxrwxrwx  1 administrador administrador   17 abr  3 18:32 libgdal.so.1 ->
> libgdal.so.1.16.2
> lrwxrwxrwx  1 administrador administrador   19 abr  3 18:32 libNCSCnet.so ->
> libNCSCnet.so.0.0.0
> lrwxrwxrwx  1 administrador administrador   19 abr  3 18:32 libNCSCnet.so.0
> -> libNCSCnet.so.0.0.0
> lrwxrwxrwx  1 administrador administrador   19 abr  3 18:32 libNCSEcwC.so ->
> libNCSEcwC.so.0.0.0
> lrwxrwxrwx  1 administrador administrador   19 abr  3 18:32 libNCSEcwC.so.0
> -> libNCSEcwC.so.0.0.0
> lrwxrwxrwx  1 administrador administrador   18 abr  3 18:32 libNCSEcw.so ->
> libNCSEcw.so.0.0.0
> lrwxrwxrwx  1 administrador administrador   18 abr  3 18:32 libNCSEcw.so.0
> -> libNCSEcw.so.0.0.0
> lrwxrwxrwx  1 administrador administrador   19 abr  3 18:32 libNCSUtil.so ->
> libNCSUtil.so.0.0.0
> lrwxrwxrwx  1 administrador administrador   19 abr  3 18:32 libNCSUtil.so.0
> -> libNCSUtil.so.0.0.0
> lrwxrwxrwx  1 root          root            12 abr 19 11:30 libogrjni.so.1
> -> libogrjni.so
> lrwxrwxrwx  1 root          root            12 abr 19 11:30 libosrjni.so.1
> -> libosrjni.so
That looks good
> But GRASS still looks for libgdal1.6.0.so.1
Did you
make distclean
configure <custom configure options>
make
for GRASS after removing the default ubuntu gdal installation?
Markus M
> </INFO>
> <ERROR timestamp="10:56:35">
> GDLA error while import. Unable to create input location from input
> /home/administrador/grass/temp/45ccd92d-daf2-4d80-abc3-a3e14bbc3f4f.tif GDAL
> log:
> /usr/local/grass7.0.svn-x86_64-unknown-linux-gnu-10_11_2012/bin/r.in.gdal:
> error while loading shared libraries: libgdal1.6.0.so.1: cannot open shared
> object file: No such file or directory
> </ERROR>
> Thank you so much for your help,
> Santi
> 2013/4/22 Markus Metz <markus.metz.giswork at gmail.com>
>> On Sun, Apr 21, 2013 at 12:42 PM, stimon <stimonmail at gmail.com> wrote:
>> > ... when I try to launch r.los (via WPS) I get a GDAL related error.
>> > From the log:
>> > <ERROR timestamp="11:50:28">
>> > /home/administrador/grass/temp/ccb06c6f-74ba-4c6d-9d14-16b62b9b9067.tif
>> > GDAL
>> > log:
>> > shared
>> > </ERROR>
>> > I have installed GDAL 1.9.2 in ~/gdal192. the LD_LIBRARY_PATH is set:
>> > administrador at torrevision:~/gdal192$ echo $LD_LIBRARY_PATH
>> >         libgdal.so.1 -> libgdal1.6.0.so.1
>> >         libgdal.so.1 -> libgdal.so.1.16.0
>> There are two links called libgdal.so.1, For gdal 1.9.2 you would need
>> libgdal.so.1 -> libgdal.so.1.16.2, but you have libgdal.so.1 ->
>> libgdal.so.1.16.0 which refers to gdal 1.9.0. The first link,
>> libgdal.so.1 -> libgdal1.6.0.so.1 comes most probably from an older
>> gdal version that was probably installed system-wide and then only
>> partially removed. Quite a mess it seems. You could either completely
>> remove all traces of the old gdal installation or hack Platform.make
>> to force link to the installation in /home/administrador/gdal192 by
>> adjusting the gdal link flags.
>> > Maybe the problem is "libgdal.so.1 -> libgdal1.6.0.so.1" because the
>> > second
>> > one it's not present while the first it is, So I also tried to set
>> > another
>> > symlink from libgdal1.6.0.so.1:
>> > libgdal1.6.0.so.1 -> libgdal.so.1
>> But now you have
>> and
>> a circularity.
>> > -rwxr-xr-x 1 administrador administrador   112705 nov 22 18:10
>> > libgdalconstjni.so
>> > -rwxr-xr-x 1 administrador administrador  1312184 nov 22 18:10
>> > libgdaljni.so
>> > libgdal.so ->
>> > libgdal.so.1.16.2
>> > libgdal.so.1
>> > -rwxr-xr-x 1 administrador administrador 44048076 nov 22 18:07
>> > libgdal.so.1.16.2
>> > -rwxr-xr-x 1 administrador administrador  5078163 nov 26 13:29
>> > libltidsdk.so
>> > libNCSCnet.so
>> > libNCSCnet.so.0 -> libNCSCnet.so.0.0.0
>> > -rwxr-xr-x 1 administrador administrador   590457 nov 22 14:34
>> > libNCSCnet.so.0.0.0
>> > libNCSEcwC.so
>> > libNCSEcwC.so.0 -> libNCSEcwC.so.0.0.0
>> > -rwxr-xr-x 1 administrador administrador    81508 nov 22 14:34
>> > libNCSEcwC.so.0.0.0
>> > libNCSEcw.so
>> > libNCSEcw.so.0 -> libNCSEcw.so.0.0.0
>> > -rwxr-xr-x 1 administrador administrador  8644546 nov 22 14:34
>> > libNCSEcw.so.0.0.0
>> > libNCSUtil.so
>> > libNCSUtil.so.0 -> libNCSUtil.so.0.0.0
>> > -rwxr-xr-x 1 administrador administrador   713782 nov 22 14:34
>> > libNCSUtil.so.0.0.0
>> > -rwxr-xr-x 1 administrador administrador   608641 nov 22 18:10
>> > libogrjni.so
>> > libogrjni.so.1 -> libogrjni.so
>> > -rwxr-xr-x 1 administrador administrador   472066 nov 22 18:10
>> > libosrjni.so
>> > libosrjni.so.1 -> libosrjni.so
>> > I don't know if I am making a mess, but I don't know what else I can do.
>> > I
>> > have been about 3 hours searching and reading about this lib problem
>> > without
>> > sorting it out.
>> > I have to say GDAL works fine, I installed it to work with AIG rasters
>> > in
>> > Geoserver before trying GRASS. However with GRASS I get this error.
>> > Thank very much for your help.
>> > Santi
>> > View this message in context:
>> > http://osgeo-org.1560.x6.nabble.com/GDAL-libgdal1-6-0-so-1-error-REPOST-tp5048562.html
>> > Sent from the Grass - Users mailing list archive at Nabble.com.
>> > _______________________________________________
>> > grass-user mailing list
>> > grass-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/grass-user
