[GRASS-user] Rendering labels in GRASS Cartographic Composer from vector layer
Anna Kratochvílová kratochanna at gmail.com
Mon Apr 22 13:26:57 PDT 2013
On Sun, Apr 21, 2013 at 8:27 AM, RichardC <richtcooper at hotmail.com> wrote:
> It appears I can set the label size (map units) from the command line and the
> label re-sizing works as expected (provided I omit the fontsize option).
> However, I can't seem to omit the fontsize option if running from the module
> window.
yes, the problem is that after you change the fontsize option in the
dialog, now there is no way to disable it, you have to close it and
open it again. Related ticket 1048 [1].
As for the cartographic composer, labels are not yet supported. I will
try to add it soon. Meanwhile, you can export the instructions file,
add labels instruction there and run ps.map with this file. Do not
forget to change region appropriately (region settings from the
instruction file header).
Anna
[1] http://trac.osgeo.org/grass/ticket/1048
> E.g. this works for a lat long layer, input in the command console, where
> the labels change in size on zooming.
> v.label labels=hydro_africa_lables.lbl map=hydrobasins_africa at hydrolayers
> column=MAJ_NAME size=0.25 color=red
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Rendering-labels-in-GRASS-Cartographic-Composer-from-vector-layer-tp5048403p5048538.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
