[GRASS-user] osgeo4w-64bit (with winGRASS-64bit) - testing welcome
Jürgen E. Fischer jef at norbit.de
Sun Aug 25 14:50:40 PDT 2013
Hi Markus,
On Sun, 25. Aug 2013 at 23:40:25 +0200, Markus Neteler wrote:
> On Sun, Aug 25, 2013 at 9:53 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
> > from the osgeo4w-ML, please test also winGRASS6.4.3-64bit
> Ver nice and thanks for the efforts to Juergen et al.
> It seems that the 32bit OSGeo4W needs to be removed first (right?).
Right, don't mix the installs.  You can install both, but not to the same
directory  - new installer has also an option to specify different start menu
names so that the menu entries of multiple install don't overwrite each other.
> I notice that it uses C:\Windows\system32\cmd.exe to fire up GRASS 64bit,
> perhaps that's the reason?
On 64bit windows that's the 64bit cmd - the 32bit cmd is in syswow64.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
