[GRASS-user] v.overlay not working?
Paolo Cavallini cavallini at faunalia.it
Sat Aug 31 10:12:01 PDT 2013
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Il 31/08/2013 14:02, Markus Neteler ha scritto:
> Which GRASS GIS version do you use?
6.4.2-2 from official Debian sid
>> v.overlay ainput=liguria_agricola at alessandra atype=area alayer=1
>> binput=uso_suolo_agricolo at alessandra btype=area blayer=1 output=over_xor operator=xor
>> Collecting input attributes...
>> DBMI-DBF driver error:
>> Cannot create dbf database: cat /home/paolo/Desktop/spezia/grass/spezia/alessandra/dbf/
> please report
> v.db.connect -p
Vector map <liguria_agricola at alessandra> is connected by:
layer <1> table <AGRICOLA> in database <cat
/home/paolo/Desktop/spezia/grass/spezia/alessandra/dbf/> through driver <dbf> with
key <liguria_agricola>
> AFAIK v.in.ogr does not accept identical column names. How was the map imported
> (v.info -h mapname)?
COMMAND: v.in.ogr -o dsn="//Srv09/Public/PIANIFICAZIONE
TERRITORIALE/QGIS/CARTOGRAFIA/BANCA DATI ORIGINARIE/SPLIT/COMPONENTI
PTR/COMPONENTI/V_PTR_00_A_ProvSPEZIA_COMPONENTE__LIGURIA AGRICOLA.shp"
output="liguria_agricola" min_area=1 snap=0.5
GISDBASE: \\Srv09\public\PIANIFICAZIONE TERRITORIALE\QGIS\CARTOGRAFIA\BANCA DATI
ORIGINARIE\ANALISI\grass
> For duplicate column names, there is the cnames parameter to rename
> them on the fly.
> http://grass.osgeo.org/grass64/manuals/v.in.ogr.html
> So (in theory) this error should not happen at all...
However, I'm talking about duplicate entries in CAT field, not column names.
Thanks for your interest.
Paolo Cavallini - Faunalia
www.faunalia.eu
Full contact details at www.faunalia.eu/pc
Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.14 (GNU/Linux)
Comment: Using GnuPG with Icedove - http://www.enigmail.net/
iEYEARECAAYFAlIiI+EACgkQ/NedwLUzIr6QeACgs+qelbDyZ7biS5dDAzXVvD3+
9dkAnion4OW2auhSAYjxg4EkCr1mUSoZ
=kGkR
-----END PGP SIGNATURE-----
