[GRASS-user] r.geomorphon add-on installation error on Arch-Linux
Margherita Di Leo diregola at gmail.com
Tue Feb 5 02:58:56 PST 2013
this is just to let you know that I committed (r54918) on behalf of Jarek
the add-on on the svn with changes made by the author.
Regards,
madi
On Fri, Jan 25, 2013 at 10:45 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Wed, Jan 23, 2013 at 1:30 PM, Haziq Noor Ariff
> <haziqnoorariff at gmail.com> wrote:
> > Hi,
> > I'm trying to install 'r.geomorphon' add-on module from
> > http://sil.uc.edu/downloads.html on my recently-built Arch Linux system
> with
> > GRASS7-svn.  I've used this module on my old Ubuntu system a-lot, but
> > somehow I can't get it to install on Arch..
> > I did:
> >  $ make MODULE_TOPDIR=/usr/local/grass-7.0.svn
> >  $ sudo make MODULE_TOPDIR=/usr/local/grass-7.0.svn install
> > The 'make' command gives no error. The 'make-install' command gives an
> error
> > that says:
> > /usr/bin/install -c  /usr/local/grass-7.0.svn/bin/r.geomorphon
> > /usr/bin/install: ‘/usr/local/grass-7.0.svn/bin/r.geomorphon’ and
> > ‘/usr/local/grass-7.0.svn/bin/r.geomorphon’ are the same file
> > make: *** [install] Error 1
> > What should I do? I didn't get this error in Ubuntu... Would appreciate
> any
> > help, thanks!
> On Fedora F17 I get:
> main.c: In function ‘main’:
> main.c:317:5: error: implicit declaration of function
> ‘radial2cartesian’ [-Werror=implicit-function-declaration]
> main.c:352:2: error: implicit declaration of function
> ‘write_contrast_colors’ [-Werror=implicit-function-declaration]
> cc1: some warnings being treated as errors
> make: *** [OBJ.x86_64-unknown-linux-gnu/main.o] Error 1
> This needs to be fixed by the author...
> Markus
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Margherita DI LEO
Postdoctoral Researcher
European Commission - DG JRC
Institute for Environment and Sustainability (IES). Unit H03 – FRC
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo at jrc.ec.europa.eu
Disclaimer: The views expressed are purely those of the writer and may not
in any circumstance be regarded as stating an official position of the
European Commission.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130205/0aebd852/attachment.html>
