[GRASS-user] Count points in a network between two locations
Markus Metz markus.metz.giswork at gmail.com
Tue Feb 5 10:36:45 PST 2013
On Tue, Feb 5, 2013 at 5:54 PM, Moritz Lennert
<mlennert at club.worldonline.be> wrote:
> On 05/02/13 16:56, Markus Metz wrote:
>> On Tue, Feb 5, 2013 at 5:22 AM, Moritz Lennert
>>> On 04/02/13 18:54, Moritz Lennert wrote:
>>> in the code of v.distance, there is a TODO at that point related to
>>> this issue:
>>> "/* TODO: all cats of given field ? */"
>>> So, either we have to enhance v.distance to take into account all cat
>>> values
>>> in a given layer, or for this particular issue, the old version of
>>> v.net.allpairs is actually easier to use. Maybe a flag to v.net.allpairs
>>> could allow to not remove duplicates ?
>> In the current version, v.net.allpairs does not remove duplicates, it
>> avoids duplicates.
> Yes, sorry for the misformulation.
What I meant was that it is not possible to simply deactivate
duplicate removal because duplicates are never created. Adding such a
flag would mean to add the code of the version with duplicates, then
run either version 1 or version 2.
Markus M
>> The current output is more in accordance with the
>> GRASS vector model, but if this output is more (or too) difficult to
>> post-process, it can be reverted to the old behaviour.
> I'm all for the accordance with the vector model, and so am not sure I would
> like to see this reversed. Ideally, it is v.distance that would need to be
> enhanced to take into account multiple cats in from and to features.
> However, if enhancing v.distance proves a bigger challenge, I thought that
> maybe we could create a flag in v.net.allpairs that if set would create
> output in the old way (duplicate lines) in order to allow treatment such as
> the v.distance one I explained.
>> I would suggest
>> to wait for some more feedback.
> Ok.
> Happy hacking at the sprint !
> Moritz
