[GRASS-user] Differences Between ERDAS and GRASS About NDVI Statistics
Gökçen Güner gokcenguner at gmail.com
Sun Jan 13 16:48:25 PST 2013
Hi Nikos,
Thank you for reply. I don't have exact NDVI band statistics but I have
statistics of NDVI difference maps. We calculated NDVI's of different times
for same area and then subtract one from another. I mean we have NDVI of
2000 and 2010 for the same area and we subtracted NDVI 2000 from NDVI 2010.
I can send statistics of original NDVI files tomorrow. These are statistics
of difference maps. I attached them to my post.
I'm not sure about 'different pixel inclusion rules' but I think
'spatial resolution
and extent' is same for both, you can see it in stat files I sent. Also we
didn't use MASK in both.
Thanks.
2013/1/14 Nikos Alexandris <nik at nikosalexandris.net>
> On Monday 14 of January 2013 01:03:42 Gökçen Güner wrote:
> > Hi,
> Hi!
> > This will not be a specific GRASS question. My friend and I tried to
> > calculate NDVIs of same data set and results seem same to us. But
> checking
> > statistics of each output we saw that statistics are very different. I
> > mean, median, mean, std.dev values of Grass output and Erdas output are
> > different.
> How different?  Can you please post exact numbers if that is ok? If
> differences
> are minor, you can simply ignore them :-)
> > We couldn't find an explanation for this situation. What can be
> > the reason for this?
> There are reasons. For example, different pixel inclusion rules (of course
> I
> have in mind border-near pixels). Other reasons might be the spatial
> resolution and extent (remember, GRASS-GIS is strict with that) and the
> presence of a MASK.
> The experts might give better clues.
> Best, Nikos
> > PS:
> > For NDVI, we used this formula: (NIR_Band - RED_Band) / (NIR_Band +
> > RED_Band)
> Note, grass7 has i.vi for this job :-)
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130114/bd800546/attachment-0001.html>
Driver:
GDAL provider
HFA
Erdas Imagine Images (.img)
Dataset Description
G:\differenceimagendvi2000-2005.img
Band 1
LAYER_TYPE=athematic
STATISTICS_EXCLUDEDVALUES=
STATISTICS_HISTOBINVALUES=1176|49|0|49|0|0|49|0|0|0|0|0|0|0|0|98|147|0|0|0|0|0|0|49|0|0|0|0|0|0|49|98|245|343|49|98|49|98|196|147|196|343|441|441|735|980|1225|1911|3234|2744|2107|1764|2009|1421|3675|5929|10094|12054|15141|17689|22393|23275|30233|23765|40229|35084|36701|36407|37240|38171|35133|34104|36113|32536|32536|30821|31752|30576|28763|29449|30772|29596|27930|28665|25970|20580|19747|19747|19257|18130|20482|20874|20923|18816|20433|19502|23373|18963|21658|23912|26803|28910|26558|27440|27048|28322|26999|26852|25284|30772|31654|34986|39249|40425|45864|52822|62573|64827|77322|84623|101332|109711|130781|143619|178605|206976|245784|292530|14293447|453103|590450|759451|1044876|1397529|1853719|2317896|2881298|3451903|3910641|3886631|3258745|2289917|1465884|944475|653513|468293|373821|300860|248479|212464|187719|165473|149646|134554|120393|111475|100450|88788|87171|78008|76195|67865|60858|59584|55566|51646|52479|45864|44982|44100|41454|43071|42826|44100|47040|48118|51107|55174|52283|48902|46158|38465|33271|29106|29547|23912|22393|20237|17493|19796|19355|16856|24010|22785|24402|22001|25284|23520|25921|30233|31850|31801|35035|38563|42532|34202|29204|23961|25431|29449|23912|22246|14112|5586|1470|3430|10731|7399|5880|8722|6272|4116|735|490|441|196|343|245|392|245|98|98|343|147|98|294|49|147|98|196|98|147|196|49|147|147|147|196|147|98|49|98|98|49|98|153027|
STATISTICS_HISTOMAX=2
STATISTICS_HISTOMIN=-2
STATISTICS_HISTONUMBINS=256
STATISTICS_MAXIMUM=2
STATISTICS_MEAN=0.12239306770747
STATISTICS_MEDIAN=0.125
STATISTICS_MINIMUM=-2
STATISTICS_MODE=0
STATISTICS_SKIPFACTORX=7
STATISTICS_SKIPFACTORY=7
STATISTICS_STDDEV=0.25389091378836
Dimensions:
X: 7651 Y: 7031 Bands: 1
Origin:
601785,4.25612e+06
Pixel Size:
30,-30
No Data Value
2.14748e+09
Data Type:
GDT_Float32 - Thirty two bit floating point
Pyramid overviews:
Layer Spatial Reference System:
+proj=utm +zone=36 +datum=WGS84 +units=m +no_defs
Layer Extent (layer original source projection):
601785.0000000000000000,4045185.0000000000000000 : 831315.0000000000000000,4256115.0000000000000000
Band
Band 1
Band No
1
No Stats
No stats collected yet
Driver:
GDAL provider
GTiff
GeoTIFF
Dataset Description
D:\gis\grassData\etm\ndviDiff.TIF
AREA_OR_POINT=Area
Band 1
COLOR_TABLE_RULE_RGB_0=-1.234239e+000 -7.590971e-001 255 255 0 0 255 0
COLOR_TABLE_RULE_RGB_1=-7.590971e-001 -2.839548e-001 0 255 0 0 255 255
COLOR_TABLE_RULE_RGB_2=-2.839548e-001 1.911875e-001 0 255 255 0 0 255
COLOR_TABLE_RULE_RGB_3=1.911875e-001 6.663298e-001 0 0 255 255 0 255
COLOR_TABLE_RULE_RGB_4=6.663298e-001 1.141472e+000 255 0 255 255 0 0
COLOR_TABLE_RULES_COUNT=5
STATISTICS_MAXIMUM=0.97340524196625
STATISTICS_MEAN=0.00097015961553423
STATISTICS_MINIMUM=-1.1823400259018
STATISTICS_STDDEV=0.14471098370192
Dimensions:
X: 8081 Y: 7121 Bands: 1
Origin:
601785,4.25702e+06
Pixel Size:
30,-30
No Data Value
-3.40282e+38
Data Type:
Pyramid overviews:
601785.0000000000000000,4043385.0000000000000000 : 844215.0000000000000000,4257015.0000000000000000
Band
Band 1
Band No
1
Min Val
-1.1823400259
Max Val
0.9734052420
Range
2.1557452679
Mean
0.0009701596
Sum of squares
0.0000000000
Standard Deviation
0.1447109837
Sum of all cells
0.0000000000
Cell Count
57544801
